Up Topic Welding Industry / General Welding Discussion / bought me an SA-250 with 700 hrs
- - By gto_welder (*) Date 09-27-2011 01:56 Edited 09-27-2011 23:39
i just bought me an SA-250 but it is too long to fit in my truck sideways (behind the rear glass).  i know these can be chopped up to fit. Does anyone have any pics of what a chopped SA250 looks like.  Any tips on how to shorten it.  I need to shorten it about 3".
Parent - By rcwelding (***) Date 09-27-2011 02:46
Chop the truck.. Not the welder..:lol:
Parent - By pocket change (**) Date 09-27-2011 03:05
I have seen them move the radiator cover in to the radiator then move the front to the armature. I have also seen them just move the front panel back like a 200 then build a end cap. If you can find a old 200 frame just put in there.
Parent - - By Cumminsguy71 (*****) Date 09-27-2011 18:54
What kind of truck do you have an s10? Seems my 250 is only 68 or 70" long end to end. Ok, 67-1/2". You might chop 3-4 off the panel side but to make them shorter length wise it seems you might be limited just because of the internals. Putting it on a 200 frame won't make it much shorter. Think my 200 overall was still almost 67" long from tip of the cone to end of the machine, maybe a +/- in there.
Parent - By gto_welder (*) Date 09-27-2011 20:13
The welder is going on a 1999 f350.
Parent - - By pocket change (**) Date 09-27-2011 23:18 Edited 09-27-2011 23:26
Yeah your right. I was thinking he was wanting the shorter frame. How is it not fittin into a 96" bed you should still have 28" if your toolbox is in the way buy a new toolbox. Can you turn it sideways behind back window. I have seen them but dont know what they had to do for it to fit
Parent - By gto_welder (*) Date 09-27-2011 23:40
I meant sideways (post edited)
Parent - - By Rafter_G_Weldin (***) Date 09-28-2011 11:58 Edited 09-29-2011 01:13
Put it in a 200pipe frame and body and it'll fit yes I have seen it but never done it
Parent - - By JeremyW83 (***) Date 09-28-2011 23:45
A buddy of mine just trimmed the bed rails and it fit right in there.
Parent - - By Rafter_G_Weldin (***) Date 09-29-2011 01:15
Some guys don't like doing that I know I don't ill tub it out the length of the bed before I cut anything
Parent - - By Cactusthewelder (*****) Date 09-29-2011 02:01
I can't believe you Shad. You will notch your hood for a Light Pole but you won't notch your bed for a Machine ! What's up with that sh*t ?
Parent - - By Rafter_G_Weldin (***) Date 09-29-2011 02:56
It was time for a new radiator
Parent - - By texwelder (***) Date 09-30-2011 02:47
We are gonna hear about you and that light pole making out in the parking lot from now on LMAO
Parent - By Rafter_G_Weldin (***) Date 09-30-2011 11:38
Thanks to good ol Cactus I'm sure you're right.
Parent - By Tommyjoking (****) Date 09-29-2011 02:58
Why modify a perfectly good welding machine?!?!?  you can remove your truck bed and build a hell for stout flatbed for less then 600.  If you are careful you can build a welding bed and skirt it for under 1000 -toolboxes.  Modify the truck to suit the machine screw messing with the machine to carry a welder in a pickup bed. If things go your way you will want a welding bed anyway so why not start that way within your budget and add as you go.
- By gto_welder (*) Date 09-29-2011 02:55
I dont líke the idea of cutting the bed.  I started modifing the machine today I think its gonna come out looking good.
