Up Topic Welding Industry / General Welding Discussion / Flex O Prene
- - By Tommyjoking (****) Date 12-22-2011 14:43
I usually try to buy Excellene or Carol welding cable.  I found a pretty good deal on some Flex O Prene.  Anybody used it before? Is it worth a flip or just cheap?
Parent - - By Cumminsguy71 (*****) Date 12-22-2011 22:58
Don't know anything about it Tommy but apparently you can get it at Walmart....
http://www.walmart.com/ip/Direct-Wire-and-Cable-Inc-Black-FLEX-A-PRENE-Welding-Cable-50-Box/15722689
Guess that tells us where it is made at least....:lol:
Parent - - By ccpi Date 12-24-2011 02:07
I use the the 2/0 Flex-A-Prene.  It's not too bad.
Made in the USA btw.  http://www.directwireusa.com/About/
Parent - - By Cumminsguy71 (*****) Date 12-24-2011 10:20
That's good to know, the made in USA part. Does it hold up pretty well? Shielding don't get damaged to easy, nick, tear?
Parent - By ccpi Date 12-24-2011 16:50
Flex-A-Prene and Caroleprene both have EPDM jackets so they will wear about the same.  The only difference seems to be the strand count of the copper.  The Carolprene 2/0 has 1248 strands of 30 gauge while the Flex-A-Prene has 1235 strands of 30 gauge.  I have had this cable for about a year and a half and so far so good.
Merry Christmas!
Curt
Parent - - By empire welding (**) Date 12-24-2011 16:44
I have about 300' of 1/0 flex o prene and it is pretty good cable.
Parent - By Tommyjoking (****) Date 12-24-2011 17:07
I appreciate the replies.  A spool of cable is a good chunk of $ that is hard to part with if you are unsure of the quality.  I found a spool of 1/0 a guy will let go at $2 a foot!!
Merry Christmas!
