Up Topic Welding Industry / Technical Discussions / Best Filler for 90/10 CuNi pipe to A-53 Carbon steel pipe
- - By Kix (****) Date 01-25-2012 14:31
In your opinion, which is a more user friendly TIG rod for joining these 2 base materials.  Right now we use ERNi-1 which works, but is tricky.  Would ERNiCu-7 be a better alternative in everyones opinion?
Parent - - By ozniek (***) Date 01-26-2012 05:56
Hi Kix
I would not go for ERNiCu-7, because if you get too much Fe dilution you will get cracking problems. Better to stick with the Ni filler or possibly use Inconel 82. Any of the high Ni alloy fillers do not flow well, so will be a bit of a challenge if you are not use to it.
Niekie
Parent - - By texasmike45 Date 02-04-2012 17:30
Parent - - By Milton Gravitt (***) Date 02-05-2012 22:01
Kix is this a job you are about to start if it is it should call out what filler material to use on the print and if it don't it is up to the customer or the engineer over the job.
                      M.G.
Parent - By Kix (****) Date 02-08-2012 13:59
We're in the early stages of qualifying a procedure to weld 90/10CuNi pipe to a carbon steel butt weld union, 150PSI max pressure and it's just water flowing through it.  I know there are multiple fillers that will suffice for this operation and just wanted to use the most user friendly in this particular case.
