Up Topic Welding Industry / Technical Discussions / Hot Rolled, Cold Formed steel
- - By maximus14 Date 01-26-2012 15:51
Is anyone welding hot rolled, cold formed steel around corners and edges?
We use EN spec 10210-1.
Our European conterparts are saying you cannot weld these areas,
Is there an AWS or ASTM spec that covers this topic?
Thanks Mike Kreith
mikih@vestas.com
Parent - By G.S.Crisi (****) Date 01-31-2012 17:38
What is exactly the piece that has to be welded?
The dished end of a pressure vessel is made from a steel plate (hot rolled) that has been either pressed or spun (cold formed) to the desired shape, and can be perfectly welded.
So, you should clear up what's the piece you're talking about.
