Up Topic Welding Industry / Inspection & Qualification / UT formula for detecting flaw depth
- - By fbrieden (***) Date 01-31-2012 01:38
% of full screen width divided by ?   I FORGOT!!!!!!
Parent - By CWI555 (*****) Date 01-31-2012 11:21
sound path x sin of the angle = surface distance
sound path x cos of the angle = depth
depth x tan of the angle = surface distance
surface distance / sin of the angle = sound path
depth / cos of the angle = sound path
surface distance / tan of the angle = depth
I use these to do the basic calcs and reverse check them.
Parent - By jwright650 (*****) Date 01-31-2012 12:26
>I FORGOT!!!!!!
Don't get too dependant on the trig functions in your machine....it is easy to forget how to figure everything off the Soundpath, if you aren't careful.
Parent - - By jwright650 (*****) Date 01-31-2012 12:29
Are you asking about locating the leg positions on the screen?  %FSW = Leg divided by the Range
Soundpath = %FSW times the Range
Parent - - By CWI555 (*****) Date 01-31-2012 14:31
The topic was "UT formula for detecting flaw depth" I assumed he was looking for the flaw depth calc.
Parent - - By fbrieden (***) Date 01-31-2012 17:18
Straight beam!
Parent - By jwright650 (*****) Date 01-31-2012 17:50
Depth = %FSW x Range
ie indication is at 32% FSW on a 5" screen
.32 x 5" = 1.6" deep
Parent - - By CWI555 (*****) Date 01-31-2012 18:53
ahh why didn't you say so? :twisted:
Parent - By fbrieden (***) Date 02-01-2012 04:55
John,
Thanks for your timely response, and sorry for not specifing mode of sound transmission. It wacked me in the head at 5:00 this AM; I just felt like a schlep because I could not remember!
