Hi Al,
Thanks for the info,one correction the pipe is schedule 80,which changes the thickness to .218" wall, my mistake.What it is I have been building these ship ladders
that have a couple of mitered joints,the contractor in the specs called out for these joints to be RT tested.So as it is the welds have to be done by a company
that has portable equipment,thus the dilemna.The clause that you recommended is the one that I have been using for reference.The commentary said Iridium can
be used as a source but only over 2.5" thickness,and all the testing companies we have spoken use Iridium.Any suggestions?
Best Regards,
Joe
