Up Topic American Welding Society Services / Technical Standards & Publications / AWS D1.1 interpretation question
- - By TSchmidt (*) Date 10-31-2012 17:19
If I am welding A204 316L pipe to a group1 plate for a fillet weld only WPS qualification. Would I need a PQR if all that is required is three macro's for the test? Please advise.
Parent - - By 803056 (*****) Date 11-01-2012 03:31
Parent - - By Shane Feder (****) Date 11-01-2012 12:00
Tschmidt,
The PQR is your record of all the actual variables from the test coupon.
Amps, volts, travel speed, material type, consumable type ,plate thickness, fillet size etc, etc, etc.
The record of test results (3 x macros) probably makes up about 5% of your PQR.
So Yes, if the joint is not pre-qualified you need a PQR,
Regards,
Shane
Parent - - By Joey (***) Date 11-02-2012 07:32
Shane, Tschmidt might be using the wrong Code (D1.1) for S/S materials.
~Joey~
Parent - By 803056 (*****) Date 11-05-2012 15:25
That's why I responded with "?".
We need more information if a reasonable response is expected.
