Brent has a valid question and the answer to that question will really help us give you an answer without guessing. But if I was guessing, it sounds like you are running 1/16" dia wire given the parameters in your original post. I have found that you can get away with 30 cfh of flow, but if any breeze is present it will uncover your gas coverage....40-45 cfh works best in our shop, just in case someone opens a door or something unexpectedly. To me the voltage looks just a bit on the low side for 1/16" with 1" ESO(3/4" works better). We run 26-30v, 250-280in/min WFS. I like to keep the whip/pause to a minimum when running fillet welds in 1F or 2F and only oscillate when it doesn't appear to be wetting in at the toes or the vertical leg isn't washing up and wetting in, or if the material is really thin and the whip and pause is to keep from burning through, other than that, just a straight smooth and steady stringer works well with our 1/16" Ultracore 71.
another question to add to Brent's:
What position are you welding in?
EDIT: I just noticed you mentioned 75/25...with argon in the mix you can get away with a bit less voltage than the 100% CO2 that we use.
