Is your verification on specs requiring a certain amount of pressure? For us something like 300 ft lbs?
The various methods of installation include differing inspection activities.
I hate using anything other than snug tight. Too much work...
I'll get a couple more pics to try to explain a couple of things.
Glyn,
First, I had to look up 'podger' wrenches. To answer your question, yes, same thing. Interesting combinations of podgers; adjustable like the one previously shown and included in one of my attachments here as well, sluggers (anvil type end for hitting with a hammer to get the desired torque), open end, box end, ratcheting box ends, etc. Never knew there were so many styles available of 'spud' wrenches.
Second, took my own pic to make a point. (Compare both pics to follow this) Combination wrenches are designed with longer lengths as the applicable size for bolts get larger. Reason, with the same amount of applied pressure you get the appropriate amount of torque applied to the bolt size requirements at hand. So also are spud/podger wrenches. They get longer as the size increases in order for the average iron worker to be able to get the proper amount of torque applied to the bolt specs in use without need of some form of cheater bar.
So, as I already stated, I use one with an adjustable (commonly here in the states called a crescent wrench though that is a trade name for one of the most common) end so I don't have to carry several with me. For inspections it is only needed to verify the nut is indeed snugged down sufficiently and if so desired, as John did, to tighten "OCCASIONAL" loose nuts. With the change in the wording for the proper inspections all we need do is twist by hand and if it doesn't come loose it is good enough. This is based upon some research that was previously included in the Commentary of RCSC Bolting Specs and still is about tightness, hole tolerances, and several factors applicable to structural integrity. I still carry a wrench incase I come upon the stray loose bolt/nut.
