Up Topic American Welding Society Services / Certifications / AWS D14.1 question
- - By patriot (*) Date 09-19-2013 17:36
Does AWS D1.1 structural code welder qualification cover D14.1 construction equipment code qualification, assuming we're dealing with the same materials, process, etc?
Parent - - By TimGary (****) Date 09-19-2013 17:51
See D14.1 : 2005, Section 1.2.1 and 9.1.4.
Tim
Parent - - By patriot (*) Date 09-19-2013 18:18
I don't have a copy of the code....just need a quick clarification.  Thanks.
Parent - - By TimGary (****) Date 09-19-2013 18:39
1.2.1 - Acceptance shall be as agreed upon between the Manufacturer and the Owner (purchaser). etc.  etc...   Acceptance criteria for production welds different from those stated in this specification may be used provided they are suitably documented by the proposer and approved by the Engineer. etc. etc..
9.1.4 - Procedures previously qualified under earlier editions of this specification, AWD D1.1, AWS B2.1 or ASME IX for equivalent welding shall be acceptable under this specification, subject to the limitations of variables in Section 9. etc   etc SWPS ok, etc. New qualifications shall be made in accordance with the requirements of this specification , or the latest edition of B2.1, subject to the limitations of variables in Section 9.
So, the short answer is yes, depending on the circumstances and prior approval, but D14.1 Section 9 takes precedence.
Parent - By patriot (*) Date 09-19-2013 18:43
Thank you, sir!  This is what I thought, but wanted it clarified.  I appreciate you kind input.
