Up Topic American Welding Society Services / Technical Standards & Publications / Re-entrant corners
- - By SCOTTN (***) Date 11-06-2013 14:20
Re-entrant corners of cut material…..
Beam copes and weld access holes at 5.17 doesn’t mention a minimum radius.  5.16 states that reentrant corners of cut material must be formed to a radius not less than 1”, but doesn’t mention what this applies to.  It’s my understanding that the 1” radius applies to everything that is cut.... (with "cut" meaning cope cuts), including beams, connection plates, bent plates, angles, channels, tubes… i.e., everything that is coped.  But…
Under “copes, blocks, and cuts”, AISC states that all reentrant corners must be shaped notch free to a radius.  An appropriate minimum radius to which this corner must be shaped is ½”.
The two codes seem to contradict each other in the way they’re worded.  It has always been my practice to cope main members with a ½” radius and to cope secondary members with a 1” radius whenever possible.  However when this is not possible/practical in secondary members, they’re coped with a ½” radius.
Regardless, the cope has to be smooth and free of notches.  We recently did a job in Wyoming and a third party inspector was in our shop checking cope radius with the back of a key.  He would run the back of the key back and forth on the radius, and if it wasn't perfectly smooth, he would reject them.  California typically has to follow D1.8, and I thought that was an interesting way to verify that the radius is smooth.  I just check them with my uncalibrated finger.
Parent - - By jwright650 (*****) Date 11-06-2013 14:27
I use a quarter to verify the radius.
Parent - - By SCOTTN (***) Date 11-06-2013 14:41
Wow! That's the biggest quarter I've ever seen.  It's almost 8" in diameter, so your cope radius is 4"? Seriously, we use a 3/8" washers from bolt bin in the stair dept. because most guys here don't own a quarter.
My concern is... where does the 1" radius apply and where does the 1/2" radius apply? As I said, it has always been my practice to cope main members with a ½” radius and to cope secondary members with a 1” radius whenever possible.  However when this is not possible/practical in secondary members, they’re coped with a ½” radius.  After all these years, I was wondering if I was interpreting it correctly.  I know some fabricators just use 1/2" R for everything.
Parent - By jwright650 (*****) Date 11-06-2013 14:44
I had some bent plate pour stop get out into the field with less than desireable radius in the cope....wow, field inspector made a huge deal out of the fact that our pourstop didn't have enough radius for him. To save the arguements, I just try to make sure that I don't miss any more and massage the ones that I catch that don't get enough radius put in beforehand.
Parent - By ctacker (****) Date 11-07-2013 05:48
I have a set of radius gages from 1/8" to 3/4", you can report the exact radius in your reports if needed.
http://www.ebay.com/itm/Starrett-SD167G-Radius-Gauge-Set-incomplete-/400595907448?pt=LH_DefaultDomain_0&hash=item5d45607378
Parent - - By welderbrent (*****) Date 11-06-2013 16:43 Edited 11-06-2013 16:46
Okay, I had to do some digging to find what I wanted here Scott.
Notice in 5.16 "except corners in connection material and beam copes".  The 1" is for other cut materials, whatever that means.  The commentary makes this very clear: "The code does not specify a minimum radius for corners of beam copes of hot rolled beams or welded built-up cross sections..."  So, we are talking about other items with corners termed "re-entrant corners".  This does not apply to WF beams with copes at the ends for connection clearance.  The code does not address those applications and tells us that is an arbitrary condition because of the variations of beam sizes and cope sizes.
Now, while AISC does give a 1/2" radius guideline it calls it an "approximate minimum radius".  I have seen many plans called out with 3/8" minumums for radius size.  And remember, the engineer is allowed to call it anything he wants according to D1.1 Clause 1.4 (the add to, delete from, etc clause).
So, I work similar to John, I use a nickel on 3/8" radius and a quarter on 1/2" radius copes.
Now, if you go by the illustrations in the commentary for D1.1 Clause 5 (Figure C-5.2 to be precise) you will notice several alterations of copes that are allowable as well as some illustrations of unacceptable ones because of notches.
If we go to the code and notice that in most applications copes only need to be ground when certain conditions apply then we need to see what roughness is acceptable.  Both AISC and D1.8 will have some guidelines slightly more strict for Seismic applications but in D1.1 for standard applications you will need to compare the torched edge of the cope to your sample #3 or 2 of the C4.1 plastic sample for torch cut edges.  As long as the roughness does not exceed those parameters they need not be ground unless there is a deeper notch than the 3/16 allowed by the code, see Clause 5.15.4.4.  Then, the notch will need to be addressed for slope values stated in the code.  (It is amazing how many inspectors don't even know what this gauge is let alone do they have one in their kit)
Using a key, fingernail, or any other arbitrary means of detecting undercut, notches, roughness, etc is totally bogus and no more code compliant than welders not using rod ovens.  Inspectors using such techniques are no better than the welders they constantly complain about.  There is a right and wrong way to do everything.  They must use the proper tools, which cost money, to document the sizes of any discontinuities they would report and ask the contractor to repair.  Otherwise they haven't a leg to stand on.  BTW, I do own a set of radius gauges when really needed, but the nickel and quarter is always in my watch pocket.
Just my two tin pennies worth.
Have a Great Day,  Brent
Parent - By eekpod (****) Date 11-12-2013 14:04
I use a quarter also, or a 3/4" washer, very close and there are always 3/4" washers around the shop.
