What can I say John. There are no exaggerations and I will not deny the folks involved are what I would call hacks, but their existence isn't limited to one geographic region.
I usually get called in when there is a problem. I don't get calls if the fabricator is doing things properly. I guess you could say I get to handle the problem children of the industry.
When you need a bandage you go to your family doctor. When you need major surgery, you go to a specialist.
JTMcC,
My slice of the welding world is the structural steel industry, and though I like to attempt to mix in a little humor from time to time, I take my job very seriously, and allowing sub par work puts the general public at risk and can eventually result in a failure. I have never, nor will I ever o.k. a piece of steel to leave the shop unless it meets the job specs and the applicable codes, as there are people's lives at stake with much of what we do. In structural steel fabrication, the job specs require the fabricator to adhere to the D1.1 Structural code, the AISC codes, and D1.8 and the IBC as required. The bottom line for me is simple. The workmanship either meets these codes, or it doesn't. If it doesn't, I do my job, without nazi-like glee, and I reject it.
As I encounter issues, I always take time to explain to a welder the basis for my rejections and what the code or the spec requires. During many of my conversations with welders, a lot of them tell me that they have never heard what I'm telling them, and many times they tell me that they were told something different. I always caution them not to believe everything they're being told.... even what I'm telling them. I encourage them to respectfully ask someone to show them in a spec or a code what they're being told, and I always respectfully tell them that I can back up what I'm telling them with a code or a spec reference, and that I can show them where I got it from. They've always been very receptive to that, and seem eager to learn more. This is something I've done over the years because some of the things I was told seemed a little far fetched to me, and I wanted to know where it came from because I was, and I still am, hungry for knowledge. Yes, there are a few, as you put it, jackleg hacks, but in my experience, they are few and far between. Most of the welders I've worked with really want to do a good job, but they typically do as they've been taught to do, and in their defense, they are not idiots. I don't see it that anybody is trying to get away with anything. Over the years I've seen some crazy things but in my experience I see it as a lack of training and knowledge. I just thought it would be interesting to share one of those instances. Nothing more and nothing less.
I agree with what Scott has said.
It is unfortunate that we tend to remember the exceptions, i.e., the contractors that stand out because they tend to screw up everything they touch. The contractors that do their job are the companies that prosper in the long run. The contractors that look for the big profit by cutting corners in hopes of "getting away with it" are usually the short termers. They are here today and gone tomorrow.
The good citizen that makes a once in a lifetime mistake isn't the lawyer's bread and butter. No, the lawyer depends on the repeat offender because they represent repeat business. In my case, the contractors that try to work around the code represent profits because of repeat inspections. Their project are the memorable ones. Good contractors, well, let's say there is little profit working their projects.
If all the contractors followed the drawings and the project specifications and code, we inspectors would be out of work. Hail to the crazies, they are our reason for being.
803056 says:
I say:
If all owners verified compliance with all drawings and spec's (in the shop and in the final field product) and wouldn't pay for work outside those boundry's, I'd get almost every bid and be richer than Bill Gates : )
J
Scott,
In our bridge related work I get to see quite a bit of shop fab work (having never worked in one but watched a million tons of it unloaded from the truck), I've been pretty impressed with quite a bit of it over the last 10 years. The big structural shop in Las Vegas in particular has shipped out some very impressive work that I've laid eyes on.
Oddly enough it was done with 232 wire as opposed to a dual shield type. I can say without a doubt they have some slick 232 trigger pullers that take great pride in their work.
I have seen, and made a good living correcting it, poor to criminal fab work come out of China and Indonesian shops. I really hope the price was right because it's very expensive to correct on site. Wear a respirator cause they put the paint on THICK, and it's lead based. I have seen body filler used there.
3 American rig welders with fitters/helpers working 6/10's to 7/12's fixing junk month after month, adds up to significant dollars fast when you've already paid for the original product.
But (so far) I've not seen the hack work described almost every day on this forum in the field on any major project I've stepped foot on anywhere in the country.
Small commercial work can be a very flakey, sub farm code place, but they don't use heavy code welding very much.
J
That's exactly what my comments were referring to Larry.
Not towards the outfits that know how to run a job or two so don't misunderstand who I'm talking about when it comes to some of the hack work that goes on out there in some of the smaller out fits that Al makes a living off of... And I totally agree that welding is a science first and foremost and only becomes an art form when used to express abstract or contemporary patterns of design related to making an artistic impression.
I'm happy for you that there's a positive response to your suggestions and I hope they continue to have confidence in your advice towards continuous improvement which you'll find much more commonplace also in the successful outfits as well.
