Up Topic Welding Industry / Welding Fundamentals / odd tip but good one
- - By Tommyjoking (****) Date 01-10-2014 04:59
Keep your mouth shut and your hood down!   It really makes the jobs last longer and go smoother....like wd40 on a rusty bolt.
Parent - - By SCOTTN (***) Date 01-10-2014 17:37
Basically, there are three essential tools: duct tape, WD40 and a hammer.  If something is moving and it shouldn't be moving, duct tape it. If something isn't moving and it should be moving, use WD40.  If it still doesn't move after using WD40, hit it with the hammer.  If it breaks, tape it back together with the duct tape.
WD40 definitely has a lot of uses, but if a wheelchair athlete uses it, I think it should be declared a performance enhancing substance.
Parent - By 46.00 (****) Date 01-10-2014 22:21
We have a saying in Yorkshire, " If in doubt, give it a clout" Which translates - if your not sure, hit it with a hammer.
- By grizzzly (**) Date 05-22-2014 20:56
my old welding instructor allways said if all else fails get a bigger cresant wrench,
if that dont work go dig the instructions out of the trash can.
- By 803056 (*****) Date 05-23-2014 01:50
Pearls of wisdom, all.
- By jrw159 (*****) Date 05-23-2014 12:40
If you can't fix it with a big hammer it must be an electrical problem. :smile:
jrw159
