Milton,
I keep all the ones I test because I'm not a CWI and just in case someone questions my experience and whether I'm properly interpreting the results. I haven't had any issues with any delayed cracking in a coupon so far.
A_DAB_will_do,
You might want to consider having your doctor adjust your meds. I recently got mine adjusted. I'm now taking it every 8 hrs. instead of every 4 hrs., so that gives me 4 extra hrs. to get the childproof lid off.
I've heard arguments, discussions really, both ways. I would think a good photo would be proof enough and then future critical evaluation would be based upon the same thing you saw when the test coupons were bent.
I don't keep mine or any of the ones I do for others. The paper and my word should be good enough. Any welder can have a bad day and any customer can request a re-test to work their job especially if the welder's work is questionable. The question is mostly centered around current work quality to the specifications at hand. If a welder had a good continuity record (? here we go again) so was easily still current on his certs but after 20 yrs skills have changed, eye sight has changed, ability to keep up with technology is critical, and many other things can mean the welder just can't cut it. What difference does it make if he, or you, can produce his original test coupons? He either can or can't right now.
As to the coupon that comes up with rejectable indications a few days later, was the original lighting sufficient? Was magnification needed? Were your glasses placed at the correct distance from your retina to clearly focus on the coupon? Or, as I suggested earlier, is it possible it did change? So what. When it was originally evaluated it was acceptable. Did hydrogen cause it? Would it have been discovered if it had been allowed to cool for one or two days before testing?
Don't know. Doesn't matter. Except for personal curiosity to be satisfied. Information is king. I want to know. But, it isn't critical.
Have a Great Day, Brent
