Kent,
You need to go see your liver specialist because you're not making any sense anymore and I believe that your ammonia level is becoming too much of a problem for you to handle your emotions, especially your anger...
You should not post opinions such as you just did in an open forum and instead, send a personal message and still, If I were to have a post such as the one in question directed at me I would be compelled to report it to the moderator or the administrator... Because this is not a sound mind expressing itself Kent! It's a mind that is not working properly due to a serious medical condition such as your ESLD (End Stage Liver Disease) and, you should refrain from expressing opinions in the manner you did when you know that the encephalopathy is acting up and therefore clouding your judgment and your feelings...
I would strongly suggest that you get some bloodwork done to gauge where your ammonia level is at and as a precaution to double up on your medicine especially the lactulose...
I would also strongly suggest that you make an immediate apology here and to the moderator, and Ross as well...
Finally, I would even more strongly suggest that you stop posting in here until you get this spike in your blood ammonia level corrected and under control...
Kent, I would not tell you this if it weren't true and you know that I have experienced the same when I was waiting for my liver transplant so I'm not just talking out of my you know what pal! Go take a break and then come back when you got a handle on the ammonia... I hope you get better real soon.
