Let's say there is a busy little outfit doing D1.1 work.... All solid wire GMAW in spray transfer mode.
All production work is set in the flat or horizontal position and the work is rotated as it moves through typical flow to get all welds accomplished.
However when attaching/fitting clips, stiffeners etc. tack welds performed in the vertical position would reduce worker motion and cycle time.
Setting up a vertical fillet break tack test is easy enough it seems with prequalified configurations etc. And furthermore Table 4.12 even says that vert. uphill or downhill progressions are not essential variables for tack welders...
But how do I get the WPS for the test ?!?!?!?!
I can't use a horizontal WPS/PQR to generate a vertical tacking WPS and performance test can I ?
Do I have to perform a full CJP groove type PQR just to be in compliance in making tacks?
Am I missing an elusive tacking PQR someplace in the code ?
I know that others must have dealt with this issue in the past.
Do tell
I'm shooting from the hip this afternoon. I don't have my D1.1 with me, so here goes nothing.
1) Welding must be done in accordance with a WPS that may be prequalified or qualified by testing.
2) Only vertical uphill progression is prequalified. If one wants to use down hill progression, it must be qualified by testing.
3) Tack welds that are incorporated into the final production weld must meet the visual criteria of D1.1 unless SAW is used for the final production weld, in which case there are separate criteria for undercut.
4) Welders must follow a WPS when welding their qualification coupon. I assume that also applies to welding operators as well as tack welders.
5) There is no differentiation between qualifying a WPS for the production weld or the tack weld, since if the tack weld is incorporated into the final weld, it must meet all the requirements of the production weld.
6) Progression for vertical welds is an essential variable when qualifying the WPS by testing.
7) With the exception of SAW, rarely is the tack weld completely consumed by the production weld. Ask any one that reviews radiographic film. It is usually easy to see where the tack welds were located if the ends of the tack welds were not feathered.
Tack welds made using GMAW-spray transfer using vertical uphill progression? I don't think so.
Here is a photograph of a couple of welds made using the technique mentioned, i.e., vertical uphill progression using GMAW-spray transfer. I would not accept these welds whether they are called tack welds or production welds. The proof of the pudding is the break test. No fusion in the root and incomplete fusion between “blobs.”
I asked the welder, "What the hell are you doing?"
"I'm pulse arcing." was the reply.
Best regards – Al
