cont....
something i must know:
1-welding using MIG or MAG or TIG for root pass?
2-for welding a 9mm plate is it necessary to weld use SMAW for filling pas?
3-what PWHT should be apply?
4-i have plates of 9mm and 25mm thickness to weld on 38mm plate, can i use only one WPS? or 2 WPSes should be employed?
5-am I qualified to write?
6-what code to follow?
7-what welding processes are available at worksite and preferred by my management to use?
8-do I have a skilled welder to do the procedure qualification?
9-do I have a budget constraint for making multiple WPS?
10-do I try to google by getting more info?
what else i must know???
![eek :eek:](/f2/epx.png)
