Just to add to SCOTTN's excellent reply... did you look at Note #1 also? If not and you plan on using short circuit metal transfer, then the joint is no longer pre-qualified...
And with respect to FCAW... Gas shielding is not a requirement, so self shielding FCAW filler metal is allowed as an option unless that was eliminated which I'm not aware of...I presume you looked @ note #10 also...
Btw, I don't see the letter F designating the welding position allowed with a B-L1a-GF joint configuration...
Now B-L1-S & B-L1a-S does have the letter F in the "Allowed Welding Position" column box but, that's for SAW (Submerged Arc Welding).
