Up Topic Welding Industry / General Welding Discussion / NASA Unveils World's Largest Spacecraft Welding Tool...
- - By ssbn727 (*****) Date 09-24-2014 22:24
NASA Unveils World's Largest Spacecraft Welding Tool for Space Launch System Rocket...
The largest spacecraft welding tool in the world, the Vertical Assembly Center officially is open for business at NASA's Michoud Assembly Facility in New Orleans. The 170-foot-tall, 78-foot-wide giant completes a world-class welding toolkit that will be used to build the core stage of America's next great rocket, the Space Launch System (SLS).
SLS will be the most powerful rocket ever built for deep space missions, including to an asteroid and eventually Mars. The core stage, towering more than 200 feet tall (61 meters) with a diameter of 27.6 feet (8.4 meters), will store cryogenic liquid hydrogen and liquid oxygen that will feed the rocket's four RS-25 engines.
"This rocket is a game changer in terms of deep space exploration and will launch NASA astronauts to investigate asteroids and explore the surface of Mars while opening new possibilities for science missions, as well,” said NASA Administrator Charles Bolden during a ribbon-cutting ceremony at Michoud Friday.
The Vertical Assembly Center is part of a family of state-of-the-art tools designed to weld the core stage of SLS. It will join domes, rings and barrels to complete the tanks or dry structure assemblies. It also will be used to perform evaluations on the completed welds. Boeing is the prime contractor for the SLS core stage, including avionics.
"The SLS Program continues to make significant progress," said Todd May, SLS program manager. "The core stage and boosters have both completed critical design review, and NASA recently approved the SLS Program's progression from formulation to development. This is a major milestone for the program and proof the first new design for SLS is mature enough for production."
Work is well underway on several additional welding tools. Engineers recently completed welding all the rings for the first flight of SLS using the Segmented Ring Tool. Ten barrels also have been welded for the SLS core stage using the Vertical Weld Center. The rings connect and provide stiffness between domes and barrels, which will make-up the five major core stage structures: the forward skirt, the liquid oxygen tank, the intertank, the liquid hydrogen tank and the engine section.
SLS will be the world's most capable rocket. It will open new frontiers for astronauts traveling aboard NASA's Orion spacecraft and may also offer benefits for science missions that require its use and cannot be flown on commercial rockets. This week, engineers at NASA's Kennedy Space Center in Florida completed the crew module for the Orion spacecraft that will venture into space on a test flight in December. In addition, NASA's Ground Systems Development and Operations Program, which is transforming Kennedy to support the launch of SLS and other users, completed a major agency-level review and was approved for progression from formulation to development.
For more information about NASA's SLS, visit:
http://www.nasa.gov/sls
Rachel Kraft
Headquarters, Washington
202-358-1100
rachel.h.kraft@nasa.gov
Kim Henry
Marshall Space Flight Center, Huntsville, Ala.
256-544-0034
kimberly.h.henry@nasa.gov
Parent - - By SCOTTN (***) Date 09-26-2014 14:42
A very interesting post.  Thanks Henry.  If the SLS ends up with a mission to Mars, hopefully they can figure out why it has changed from warm and wet to cold and dry.  The only thing I can think of is, it probably got married.  Speaking of women, I think it’s still a good idea to continue sending women on space missions, because they weigh 25 pounds less than an automatic dishwasher.  Just don’t let any of them drive because there is never going to be a space big enough for a woman to park in.
Parent - By OBEWAN (***) Date 10-01-2014 20:13
"PBS" ran an interesting "Documentary" on the expedition to "Mars".  Is it real or is it Memorex?  And, those "Astronauts" will likely end up 25 lbs lighter by the time they come back - or we will need a bigger fuel tank, and a he-double-hockey-sticks lot more hydrogen.
