Aren't the material requirements specified in ASME section II? And, have you checked the base metal P-numbers listed in the code?
Do you have access to a current copy of the ASME boiler and pressure vessel code?
Following that investigation, my suggestion would be for you to seek a proper copy of the applicable wire specifications specified in the code and/or your contract documents.
If you are a student, these documents might be available at a community or technical school library.
Otherwise, if you are weldor, please ask your supervisor, QA department, or welding engineer for the answers to these questions.
Sorry, but my own hands-on experience does not include any stainless FCAW pressure vessel work, and my preference is GTAW - but this is perhaps only an opinion that might be overridden by cost issues and/or the material thickness and weld size requirements. You did say plate, so we are perhaps talking about 1/2" or thicker? Are the plates used for structural brackets?
