If you were qualified to qualify those procedures, and they were qualified in accordance with an applicable code, they should remain valid, even if you are struck by lightning, unless at some point, a change in the applicable code requires a requalification.
With a slight exception, I agree with Scott and John.
Let the CWI go (don't renew the quals with AWS), move on, retire, or, God forbid, get struck by lightening, the PQR and any WPS's written off of it will remain in effect.
Now, even if the code changes, for the most part it still remains in effect. May be prudent to review, revise, and sometimes even redo, but the old one is qualified as long as it was valid in the first place. That is, the WPS is revised, you can't revise a PQR, it is what it is. But once qualified to a current code, it is good. That doesn't mean the engineer has to accept if for his job. He may direct a new PQR even if it is still good under the current code just because he wants to see lower heat input, or different parameters somewhere else. But, the first PQR is still good and can be used for a good many jobs. See D1.1, 4.3.1.
