Up Topic American Welding Society Services / Technical Standards & Publications / D1.2 material thickness (WPS)
- - By flamin (**) Date 12-23-2014 14:30
Hi All,
It's bee awhile since I posted, but I have a question I am unsure of.
We are fabricating an aluminum weldment, 6061-T6.
Outer shell is Ø16.25" O.D., 1/4" thick rolled and welded tube.
On both ends is a flange that is .88 thick, that slips into the tube .38" deep.
Please see attached sketch.
[img][/img]
Our WPS is qualified to 1/2" thickness for groove welds, I'm thinking even though we are only welding a 1/4" thick joint, the WPS doesn't cover the thickness of the thicker member. However, I cannot find in D1.2 (2003) where is says anything about welding different thickness materials, which leads me to believe our WPS will not work for this application. Am I correct?
Thanks
Parent - - By jwright650 (*****) Date 12-23-2014 14:48
I don't have D1.2 handy, but looking at your sketch, it seems to me that the 1/4" thickness is governing your material thickness for the WPS. That is the point where your CJP (through thickness) is taking place. The cap plate thickness of 7/8" is irrelevant in my opinion.
Parent - - By flamin (**) Date 12-23-2014 15:05
Sounds logical. So regardless of the material thickness, only the joint thickness is relevant?
Thanks.
Parent - - By jwright650 (*****) Date 12-23-2014 15:52
Well... in my mind, you are not actually welding a full 7/8", only the 1/4" CJP wall thickness....so the 7/8" thickness is irrelevant, it could be 2" thick, and you would still be welding 1/4" CJP.
Parent - - By SCOTTN (***) Date 12-23-2014 16:42
Wouldn't the 7/8" thickness still be relevant with regard to preheat?
Parent - - By welderbrent (*****) Date 12-23-2014 17:43
Scott,
Is preheat a consideration for D1.2, especially only 7/8"?
Parent - - By SCOTTN (***) Date 12-23-2014 18:12
I don't have a D1.2, so I can't answer that.  I've heard that preheat can help, but I've also heard that with the right equipment, it's not necessary.  I was just asking the question.  I would think that preheat could increase the heat affected zone and reduce the mechanical properties of welded joints in certain aluminum alloys.
Parent - - By flamin (**) Date 12-23-2014 18:44
Just to clarify,
Our WPS only gives a min/max preheat/interpass temp. range. So as long as we're within that range we should be good.
As far as I can tell in D1.2 (2003), it only discusses maximum heat exposure time at temperature (Table 4.5) and nothing about min preheat.
Parent - By fschweighardt (***) Date 12-24-2014 00:53
Fwiw, that probably should be a symbol that shows backing, with wps, pqr, etc. To match
- - By 803056 (*****) Date 12-24-2014 03:45
A WPS qualified to 1/2 inch thick should be fine since the weld is only 1/4 inch.
The bottom is nothing more than backing. That being the case, the welding symbol could include a backing symbol. It would reinforce the idea that the weld completely penetrates the thickness of the 1/4 inch shell. Just don't include the letter "R" in the backing symbol or the purpose of the 7/8 inch thick bottom might be compromised!
Merry Christmas!
Parent - By flamin (**) Date 12-24-2014 13:52
Good points guys, our WPS is good to go.
Once again I do appreciate everyone' advice and help. Sometimes my mind goes in circles, and nothing seems to fall in place.
Happy Holidays
