You direct the question to the Engineer and ask for the information.
Refer to AWS D1.1:2010, clause 2.3.2 and clause 4, Part D.
The clause you reference is for a standard 3 piece set of Charpy test specimens. Each of the three pieces must meet some minimum value. If the absorbed energy is too low for any of the three samples, the PQR fails. If option B is specified, only 3 of the 5 are included for acceptance. The 2 samples that are discounted is the (one) highest and the (one) lowest test value. The three remaining are included in the final evaluation. If any one of the three included in the evaluation has a value lower than the minimum, bad news, the PQR fails. Also two of the three specimens must have a value equal to or more than the average value of the 3 piece set. If two specimens are lower than the average, do not pass go, start again.
