I took this out from the post I had most of this written in the D! section because it's probably better off here so that the knit pickers don't get all huffy & puffy about posting stuff in the wrong place and what not... I'm too frail to get into a debate over such petty crap so it's better for me to avoid that like the plague... it's kind of funny now that I think about how I started with what was supposed to be a quick personal note to update Tim on my medical condition, and mushroomed into a detailed description of the procedure including images and web links... @ that point I said to myself: "Someone's going to complain so I just better post it in the OTB&G so I can avoid any BS from those hyper-perfectionist types that always seem to piss me off and is the last thing I want to do especially in my condition... So here it is:
On a personal note, I had the Thoracentesis and a lung biopsy done Friday and so far so good as I'm back home resting and waiting to heal so they can check to see if the thoracentesis alone re-inflated the lung which will complete the procedure... This is the part that's 70-30 odds for the lung not being able to keep itself inflated on it's own... Nonetheless, I'm still hopeful that mine will because from what they viewed in the MRI and the nuclear scan which didn't show any scar tissue in the collapsed section of my left lung to indicate an unfavorable condition... The biopsy will confirm it hopefully...
When I go back next week, they'll perform another ultrasound to check if some more fluid has replaced what was drained out of the pleural effusion... This happens often and sometimes they have to perform the Thoracentesis as many times as necessary until the fluid no longer accumulates at the location of the pleural effusion... After this procedure is successful, we can start the transition of weaning me off the oxygen but that will only happen if this procedure repaired the leaking Tricuspid valve in my heart... I'm praying that it will.
Keeping positive and so far so good.
Here's link to show what the procedure entails and why is it done:
http://sfgh.medicine.ucsf.edu/education/resed/procedures/thoracentesis/PDF/Thoracentesis.pdfP.S. this is what a Thoracentesis is like:
https://www.youtube.com/watch?v=UBY3cQiQ6KoThey used an ultrasound to guide the needle to the pleura safely:
http://www.acep.org/Education/Continuing-Medical-Education-%28CME%29/Focus-On/Focus-On--Ultrasound-for-Thoracentesis/I also attached some images below... Thank you all for your continued support!!! We're halfway through to re-inflating my left lung.
