Edge joints are mostly applicable to D1.3 and other codes involving thinner members.
BUT, They are still usable to heavier sections as well. Engineer/detailer needs to provide information for a PJP as I see it (unless they actually want you to do a CJP through several inches of steel
). Information like depth of bevel, bevel or V, depth of weld, angle of bevel, etc.
It would be considered a groove weld call the joint what you will depending upon all applicable factors. Mostly butt joints as Lawrence mentioned.
I can't think of an application where an edge joint would have a fillet weld.
