Hi Eugeny!
Here are some links to possible documentation to back you up in order to justify your suggestions to your management of the welding preheat, and PWHT or not when hardfacing stellite 6 to (what is the CE for the grade of steel being hardfaced?) steel:
http://www.stellite.co.uk/Portals/0/Guidelines%20for%20hardfacing%20onto%20steels.pdfFor this link, scroll down the .pdf to page 37 of 59:
http://c.ymcdn.com/sites/www.vma.org/resource/resmgr/2012_technical_seminar_&_exhibition/dr._danie_de_wet.pdfHere's an interesting thread in the Engineering Tips forum that sort of mirror some of the comments found in this thread:
You might want to check and see the amount of Manganese in the steel in order to make sure that you either need to increase your pre heat, or if it requires PWHT, or both. Here are some more links to hopefully more helpful information and suggestions...
This link will lead you to another .pdf to download from it which explains the scope of the research that was performed on the Cracking and Disbonding of Hardfacing Alloys in Combined-Cycle Plant Valves... Although this doesn't directly pertain to nuclear components as is your application, The EPRI Customer service and technical resources contact information for their findings from this investigation:
http://www.epri.com/abstracts/Pages/ProductAbstract.aspx?ProductId=000000000001025658Here is a similar paper as the one above and below... However the information is limited to 7FA class steam turbines Combine Cycle plants:
http://globalfield.net/pages/documents/2.pdfAlthough this paper mainly talks abut SMAW electrodes as opposed to GTAW which you are using, and Combine-Cycle Plant valves as opposed to the Nuclear versions of these type of valves... There is a table # 2 which shows pre-heat temps dependent on the current (amperage) amount being applied... This table is located in page 2 of 6 in the .pdf below... I believe this is good starting point to go by as well as it being published in the May of 1992 edition of the AWS Welding Journal below...
"Cracking and Disbonding of Hardfacing Alloys in Combined-Cycle Plant Valves":
https://app.aws.org/wj/supplement/WJ_1992_05_s195.pdf This one may or may not be of interest to you but, there may be something you can take away from this study:
https://www.iaea.org/NuclearPower/Downloadable/Meetings/2013/2013-03-04-03-07-CF-NPTD/T4.4/T4.4.marlaud.pdfAnd finally this article in "Valve Magazine" covering valve repairs similar to your application except for the fact that these are not used in a nuclear power plant:
http://www.valvemagazine.com/index.php/web-only/categories/technical-topics/5144-in-line-weld-repairs-of-valve-defectsAnd this eye opener:
http://www.ans.org/pubs/journals/nt/a_33563Well, that enough for me today... I'm tired and need to sleep for tomorrow... I will be discharged too, I'm coming HOME!!!
