Up Topic Welding Industry / ASME Codes / ASME IX 2015 QW-403.5
- - By Firefly (*) Date 09-24-2015 07:59
Hi,
With reference to ASME IX 2015 QW-403.5
If we have a PQR qualified with impact testing using P1G1 to P1G2 material.  May we use this PQR to weld P1G1 to itself and P1G2 to itself when impact testing does apply?
Thanks
Parent - By Jovi Zhu (**) Date 09-27-2015 09:31
IX 2015 QW-403.5:
...In addition, when base metals of two different P‐Number Group Number combinations are qualified using a single test coupon, that coupon qualifies the welding of those two P‐Number Group Numbers to themselves as well as to each other using the variables qualified.
- - By CARA1981 Date 10-22-2015 14:04
Question: In accordance with QW-403.5, may a welding procedure specification (WPS) that is qualified with a base material P-No. 1 Group 1 be used  with a base material P-No. 1 Group 2? The WPS was qualified to Section IX - 2013 using SMAW and filler metal 7018 G.
Parent - By Don56 (**) Date 10-22-2015 20:57
If the procedure was qualified by welding P1 G1 to P1 G1 and impacts are required, the procedure is not qualified to weld P1 G1 to P1 G2.
- By CARA1981 Date 10-23-2015 18:29
A welding procedure specification (WPS) that is qualified with a base material SA 106  Gr B (P-No. 1 Group 1) can be used  with a base material  ASTM A 350 Gr LF2 Class 1 (P-No. 1 Group 2)? The WPS does not have a PQR qualified with impact testing. The WPS was qualified to Section IX - 2013 using SMAW and filler metal 7018 G.
