Up Topic American Welding Society Services / Certifications / bend test coupon tolerances
- - By jsdwelder (***) Date 11-09-2015 19:09
For those of you who work with bend test samples what degree of tolerance do you deem to be acceptable from stated dimensions in terms of width and thickness? I know AWS D1.1 and ASME do not really give a tolerance but clearly there has to be some. I mean if I mic a 3/8" side bend specimen and it comes up .374 does it fail? Or a 1" plate that after ground/machined comes in at.994? You know what I'm saying. What is generally accepted?
Parent - - By 803056 (*****) Date 11-10-2015 06:14
We discussed just a couple of weeks ago. Do a search and you can look at the responses.
Parent - By jsdwelder (***) Date 11-10-2015 13:34
Thanks. Al. Must have missed that one.
