All good information guys, appreciated.
I talked to the company some more and explained my situation to them. The company told me that one day they would like to move in the direction of welding units per the required codes, but for right now they are looking for someone that can develop a shop standard. I guess a shop standard that does not require the heavy cost of third party NDE, such as x-ray, PT, UT.... They want to stick to the old fashion eye and VT, hydro test, and diesel test.
The work is pressure vessels, heaters, boilers, separator, and battery tanks. Still would not use my stamp is this situation of course. Any ideas on where to start?
On another note, can a CWI develop a WPS or can a WPS only be developed by a SCWI?
You don't NEED either to develop a WPS, especially a pre-approved WPS. But, ONLY a SCWI is expected to be able to complete the forms properly and make sure everything is up to par.
The fun part is getting them right. Many think they can, few are able to prove it.
hevy,
I still think your breathlessness is unwarranted. You have a deep concern about the use of your stamp and yet ASME (the presumed jurisdiction of these pressure vessels and boilers) couldn't give a schit about that stamp anyway. Which means that your stamp is irrelevant to the Codes of which you have concern. In other words you are concerned about using your stamp where nobody cares if you use your stamp. I'd say use the stamp if you wish. You paid for it. All it means is that you have verified compliance with 'whatever'. It has NOTHING to do with the Codes.
And I would disagree with Brent to an extent. Some obscure 'turf oriented' asinine rule of which I am unaware notwithstanding, from a practical standpoint, anybody can write a WPS. Though he is dead on when he says that this does not mean that anybody is capable of doing it well. It is actually surprisingly difficult to get right.
Well there you have it, use your CWI knowledge to develop your in house acceptance standard for VT. Sounds like you're company is looking for some consistency in their welding and something to hold the men accountable for so they just can't run amuck with how the welds look. It's also good to have a procedure with acceptance criteria in it so the men can't accuse you of picking on them and their welds. You just have to point to bible and verse in your procedure and tell them to fix it. If the company is looking to go toward being code compliant someday, I would write your VT procedure in line with ASME Sec V making you own tweaks to acceptance criteria based off one of the piping code sections or pressure vessel code sections for the time being. These are good starting points and right now can't really be incorrect because you aren't working to any code. About your stamp. I'd keep it at home in the safe just incase someday you work for a company doing AWS code compliant work.
Kix
