There are situations where the contractor elects to qualify the WPS using a PJP groove weld. The macroetch specimens are required to verify the groove preparation is adequate to produce a weld of the required size.
As an example, should the contractor attempt to qualify a PJP groove detail with a 15 degree groove angle, all is fine as long as the weld size is as specified. The WPS would permit any groove with a groove angle of 15 degree or greater.
