Up Topic Welding Industry / Technical Discussions / vickers hardness value
- - By ali hussain Date 08-28-2016 15:40
Dear All,
I want to inquire about the vickers hardness values for procedure qualification,while material is a537 cl.2 thickness 45mm,welding with smaw process using E7018G electrode in 2G position.during welding our amp range 126-143 voltage 24-26 and heat input is 1.352-1.438 kj/mm.travel speed  140-153 mm/min.what should be the hardness values are acceptable in weld metal ,haz,and base metal and on which standard basis.
Parent - By 803056 (*****) Date 08-29-2016 02:32
"How many animals reside in the ocean daddy"
"Which ocean my son?"
Give us a clue, what customer requirements are imposed?
Parent - By MBSims (****) Date 08-29-2016 03:09
As Al said, we need more info. Where is the requirement for hardness control coming from? Customer specification? NACE?
- - By ali hussain Date 08-29-2016 05:27
dear all,
after welding vickers hardness value is base metal 226-295 in weldmetal 228-241 and in haz 244-295, according to material specifications these values are acceptable or not.please help me in the matter.
Parent - By Tyrone (***) Date 08-30-2016 13:04
Ali,
What does the Customer specify for weld metal and HAZ hardness?  I suspect he didn't specify.  If that's the case, Acceptable.
Tyrone
- - By ali hussain Date 08-31-2016 05:44
Dear Tyron,
Thank you for sharing information,I didn't find anything from a customer that's why I'm confused if you have any authentic information in the reference of specific code or standard this will be helpful to solve the issue.
Thank you in advance for your assistance.
Parent - By MBSims (****) Date 09-09-2016 02:39
This is going to sound shocking to some, but the technical requirements for a job are specified by the customer based on the laws and regulations that apply to the item and the customer's additional technical requirements. If one does not know the laws and regulations that would apply, or have any input from the customer, then there is no basis for any response.
