Up Topic AWS.org / Forum News & Help / Welding Tech Needed
- By dtoussaint Date 11-30-2016 17:14
My company is looking for a Technical Specialist for permanent hire. This is a salaried position, pay ranges from $68,000 to $145,000. As the Technical Specialist (Welding Engineer), this individual will work as a company expert in the area of welding, fabrication, materials and nondestructive testing. They will support the Welding Programs daily activities and provide multiple plant organizations welding engineering and nondestructive consulting services and support. Candidate must have over 3 years welding experience and current CWI certification.
- - By Jayant Pavnaska Date 02-02-2017 05:49
I need guidance for interpreting the requirements of the standard AWS D 1.1 sec 7. I am referring to fig. 2 clause 7.3.2.
How we can measure elongation and yield stress at 0.2% with this test.
Standard also specifies that the tensile test to be carried out as per ASTM A 370. In this case there is NO ISSUE.
Do they mean both tests are to be done? Which test will be decisive?
Please help me to clear my confusion.
Thanks
Jayant Pavnaskar
Parent - By 46.00 (****) Date 02-02-2017 23:42
You are aware this is for stud welding?
- By Johnny A Date 04-30-2017 22:30
I have a 1999 Miller Bobcat 225NT gas power welder. I want to put a foot pedal on this machine. My question is: Can I adapt a foot pedal (7 pin) to this welder?
- By welderbrent (*****) Date 05-03-2017 04:10
Looks like we have a bunch of newbies and spammers hijacking this poor guys thread about a job opportunity.
Too bad.  It isn't really a difficult forum to understand.
Start your own thread to ask a question or start a topic.
- - By 803056 (*****) Date 05-03-2017 16:28
I've got holes in my socks. Does anyone know what color thread I should use to fix the curtains?
Al:yell:
Parent - By Maggs47 (**) Date 05-03-2017 16:48
You'll need 3 pizzas to stop up the hole in your boat.
