Up Topic Welding Industry / Welding Documents & Downloads / WPS and PQR
- By Nilesh6591 Date 05-05-2017 03:55
Happy Greeting to All...
  I want to prepare WPS and PQR for the materials as SA106 Gr. B, SA 213 Gr. T11 and SA 335 Gr.P22 so please share me this requirement
- - By KCapps Date 06-27-2018 16:22 Edited 06-27-2018 16:52
Need a little help. going over some WPS's and PQR's noticing the both are signed. Each WPS has 2 different people signing off on them but the dates that used when they signed off, some are very different. ex. WPS#000 - 1 signature signed and dated 10-27-2005 the 2nd is signed and dated 7-16-2016 (I believe this one is when he started, because each WPS he found has this date). Qualified to AMSE Sec IX
Is this an issue, and if so is there any suggestion on the fix?
QA/QC
Parent - By Tyrone (***) Date 06-28-2018 14:02
Hi KCapps,
Welcome to the Original AWS Forum
In the future, start a new thread for your topic.
What are the official positions of the people signing off?
Tyrone
- By Neeraj Date 07-27-2018 10:02
Sir i am confused about piping question, i want to prepare WPS but i am not able to get my ans. please help me out.
i am execute different thiknes rang from 1.5" to 18", i want to know what quantity of WPS prepare?
- By 803056 (*****) Date 07-27-2018 14:25
You didn't specify a welding/fabrication standard, but if you are welding pipe in accordance with ASME, you start with the construction code, i.e., Section VIII, B31.1, B31.3, etc. The construction code will direct you to ASME Section IX for qualification, but you have to review the construction code to determine if CVN testing and whether post weld heat treatment is required for the thickness you are welding.
- - By KAVINKUMAR.K Date 09-20-2019 06:07
Good morning all,
                    please tell me is there any minimum qualification required to wire and qualify the WPS, PQR and also WPQ? or anyone can write the procedure which meets the all requirements in the ASME, AWS code?
thanks,
kavinkumar.k
Parent - By SWN1158 (***) Date 09-20-2019 11:56
6.1.4.1 (3) of the AWS D1.1 Structural Welding Code - Steel, states “an individual who, by training or experience, or both, in metals fabrication, inspection and testing, is competent to perform inspection of the work.” This is the minimum inspection qualification criteria in the structural welding code.
