Up Topic Welding Industry / General Welding Discussion / Welding St 35.8
- - By Keenan Date 11-28-2017 13:44
hi all welding aficionados,
I have a pipe that I need to weld. Pipe thickness is approximately 15mm thick with OD of 280mm. Parent material St 35.8.
Pipe is online with steam at op. press. 5.5Mpa and 340degrees C. What welding can be done on this pipe and would any heat treatment be required?
Thanks
K
Parent - By 803056 (*****) Date 12-01-2017 12:59
If I knew what St 35.8 was I might be able to help you. I'm not familiar with all the steel specifications used around the world. Sorry.
Parent - By Tyrone (***) Date 12-01-2017 13:14
Hi Keenan,
Welcome to the Original AWS Forum
This was previously posted.
https://app.aws.org/forum/topic_show.pl?tid=25328
