Up Topic Welding Industry / General Welding Discussion / Combination process can be used only single process - Reg
- - By AmulRaj Date 12-13-2017 03:20
Dear Experts,
We have an Dissimilar WPS (P1 & P8) with combination process(GTAW - 8 mm Max + SMAW - 11.06 mm Max)
The same WPS can be used for single process only (GTAW)
Please advice me with reference
Regards,
Amul Raj T
Parent - By 803056 (*****) Date 12-13-2017 04:42
It appears you are qualifying the WPS in accordance with ASME Section IX. If that is indeed the case, ASME allows the joint to be welded with one or more WPSs and each WPS can be for one welding process or multiple welding processes provided there are supporting PQRs.
Please verify the applicable construction code has been reviewed to check whether CVN is required and whether PWHT is required.
