Up Topic Welding Industry / ASME Codes / Thickness qualified for Welder
- By abikoswara Date 01-23-2018 02:59
My name is Abi, I wanna ask about thickness of weld metal Qualified for Welder on the ASME IX Table QW 452.1(b)
there mention for coupon of test over 13 mm, the qualification for welder is max to be welded, What is the meaning of Max to be welded ? Is it same with the unlimited ?
Thanks
- By Jmerz2046 (*) Date 01-23-2018 03:21
Maximum to be welded is in reference to the WPS And it’s max. Weld deposit. Example, If WPS has a 8” max weld deposit allowed then the welder is qualified to weld to the max allowed on WPS. Don’t no if that came out right. Hope it helps.
- By 803056 (*****) Date 01-23-2018 03:26
It is "unlimited" in the sense it is only limited by the maximum thickness permitted by the WPS. That is conditional on the welder welding an assembly that was at least 13 mm thick and deposited with at least three layers. In other words, if the 13 mm was welded in one pass, he isn't qualified for "unlimited" thickness.
