Steelslinger,
I understand all of that.
but when i see the word SHALL, and Figure 9.23, and its a "Single V-Groove" with a note ONLY about Groove Angle, that says to me that if you want to weld an open butt no backing weld, you can only use that joint detail.
What makes me wonder is that they discuss a square groove open butt/ no backing under that table, so then it makes me think they do allow different joints. I need a single bevel joint, not the single v they say you SHALL use. and being thats an essential variable if changed, it makes me wonder if your even allowed to weld any other joint detail besides a Single V for tubular structures.
I have read all through clause 9 and the commentary more than i can count. i want to see this in the code black and white, and not an opinion, and it seems not to exist.
Know you can get around this if you do a PQR on plate if your welding on 24" Pipe Minimum, but it still doesn't help my question.
