Up Topic Welding Industry / General Welding Discussion / Want to weld Carbon Steel casting
- - By Sambuddha (*) Date 05-22-2018 07:53
1.Physical Properties -700 Mpa,, Yeild 370 Elongation 8%
Chemical -C 0.52-0.58 %,Si-.60 Max, Mn-1 Max, S -0.040 Max, P 0.040 Max
Cr-0.2 Max,
Ni- 0.30 Max
Mo-0.15 Max
Cu-0.25 Max
What electrode I should go for
Parent - - By Tyrone (***) Date 05-23-2018 11:16
Sambuddha,
Listing the max. and ranges leads me to believe you know the steel type and grade.  It would be easier to suggest an electrode knowing the steel type.  Or you are posting the question that your school asked?  All your other posts have a similar flavour.
Tyrone
Parent - - By Tyrone (***) Date 05-23-2018 11:18
Not bashing you if you are a student, but you need to do some work too.  At least research what type of steel it is similar to.
Tyrone
Parent - By Sambuddha (*) Date 05-25-2018 11:17
Actually we are repairing one old machine part .We donot have any Papers regarding its composition.
So we have taken some broken parts and done the testing .
I am tried it with E10018 D2 but it has not worked .
Can you suggest me somthing Tyrone.
- - By 803056 (*****) Date 05-25-2018 16:27
The material is a medium carbon with minor alloy additions. I would approach it as a medium carbon steel, using sufficient preheat and I would use an undermatched low hydrogen filler metal if the joint is highly restrained.
Parent - By Sambuddha (*) Date 05-26-2018 05:52
Thanks AI
