Up Topic Welding Industry / Technical Discussions / welding in the K-section
- - By ididntdoit89 (*) Date 09-26-2018 13:43
We have a problem with an outside inspector. He is claiming that it is illegal to weld in the K-section of I-beams with stiffeners and connection plates. I have gone through D1.1 and AISC and I can not find where it says there shall be no welding in the k section. In AISC, i found where it is not recommended but doesnt say its illegal. Please Help
Parent - - By Lawrence (*****) Date 09-26-2018 14:32 Edited 09-26-2018 14:39
Here is an older discussion of your question.
https://app.aws.org/forum/topic_show.pl?tid=20715
If Sisemic
See AWS D1.8  2009     Clause 4.1  C-4.1  and Figures C4.1 & C4.2
Parent - - By SWN1158 (***) Date 09-26-2018 15:21
It's a seismic requirement, as Lawrence has shown. I always like to ask the inspector to show me in the code where it states that something is not allowed. That usually shuts them up :)
Parent - By jwright650 (*****) Date 09-26-2018 19:33
Ditto what the others have said.
Edit: I did have a set of job specs one time that prohibited welding in the "k" area.
Parent - By ididntdoit89 (*) Date 09-26-2018 16:30
thank you sir.  I ve already read through that post.  I just didnt know if there has been any changes in the 2015 printing and also if AISC says anything about it.
