In AWS A3.0:2010 in the "W" sections....the acronyms are slightly different for the last two that are mentioned in the post above. The Welding Procedure Specification(WPS) is listed and defined as written above, the other two (Performance Qualification Record, and a Welding Qualification Test Record) are slightly different, so be careful and make sure you are using the correct ones when looking at pages 47 and 48 in AWS A3.0:2010.
Also look in the back of the AWS D1.1 at the Sample Forms in Annex M of AWS D1.1:2015, I think it would be pretty easy to determine the differences once you browse through these forms.
