Up Topic Welding Industry / General Welding Discussion / Need clarification on welding symbol interpretation
- - By NdYAG2015 Date 01-17-2019 00:52
When a weld joint already has a bevel only cut partway through the thickness, if I do not specify the bevel depth,  is it implied that I should only weld to the bottom of the bevel or through to the other side?
Parent - By 803056 (*****) Date 01-17-2019 03:20
So, you have 3-inch thick plate and the bevel depth is only 2-inches, the question is whether to make the weld CJP or PJP. Or, is the plate 1-inch thick the bevel only 7/8-inch deep and you want to know whether the weld is CJP or PJP.
I would go to the designer and ask what his intent is.
Parent - By Tyrone (***) Date 01-17-2019 11:59 Edited 01-17-2019 12:06
Hey NdYAG,
Specifying the bevel depth doesn't tell the welder how much weld is required.
Specifying the weld size or effective throat on your drawing tells the welder how much penetration is required.
If you do not specify weld size or effective throat, it means complete penetration (weld through to the other side).
Tyrone
PS - Better to put all the details on your drawing so there's no confusion.
