I agree with both of the suggestions. However, it is very important to go to the wire feeder and loosen the drive roll from the wire so that you do'nt have alot of wire coming out of the contact tip in the welding gun when you set your cfh on your flowmeter/regulator. What a mess that could be!
Now if you have a purge button on your wire feeder or if you you have one of these buttons on your machine's front panel then, you can avoid all of what I mentioned above, and having to possibly reset your tension adjustment on your drive roll assembly. If you have a book available that covers GMAW operating instructions, you might find the necessary info in order to successfully setup, and operate the equipment so you can produce consistent high quality welds. Remember - Practice, Practice, Practice!!!
Good luck!
Regards,
SSBN 727 Run Silent. Run Deep!!!
