Turbine compressor case, even LPT,,, A36?
Are you sure?
You absolutely need to consult the original equipment manufacturer OEM of the case and acquire their standard practices for weld repair and criteria for determining engineering variances.
There may also be some guidance or a pathway to guidance for a repair approach in the governing specifications you must comply with, but you did not mention those.
That’s the only advice I will risk.
