It would depend on the edition you are using. Regardless of the edition, there is a clause that states back gouges should resemble a prequalified J-, or U-groove. Now, if you are taking the position that you are qualifying the WPS to establishing the minimum contour of a back gouge, you can do so, just make sure you record the data on the PQR.
