Up Topic Welding Industry / Technical Discussions / Scratch start GTAW
- - By BM146 Date 07-29-2004 22:42
How come the tungsten doesn't become contaminated when you scratch start a GTAW weld? Or does it?
Parent - By swnorris (****) Date 07-30-2004 11:31
Hi BM146,
A scratch start may be used in lieu of a high frequency start, and although the tungsten is briefly scratched against the work piece, there is the possibility of tungsten contamination. The arc should not be struck on a carbon block because of the likelihood of carbon contamination. Some codes do not allow scratch starts.
Parent - By jamesrodr (*) Date 07-30-2004 14:26
Hi BM146 ,
With scratch start the tungsten does get contaminated . When you use higher currents the tungsten will lose its ground point also with scratch start assuming the power source does not have the lift arc facility !
