4' X 6' or 4' X 8' 1/4"-1/2" Temperboard or any smooth, non-conductive surface works great. Sheet metal is also great. Position 2 - 4' panels into a 90 degree L and curtain a 30" door way. Pin the Ls to create booths 6 1/2 foot wide by 8 or 10 feet high, the depth can be ?. Leave or frame the sides so there is 18 - 24 inches from the floor. Great vent enhancer. Don't paint it black. Paint the surfaces with a flat non reflecting latex paint. White is great but get creative, a light blue, green or yellow or shades thereof. Don't worry about it getting dirty. Soap/detergent cleanser and water clean up or just repaint it. Put color combinations together so that you don't have a sterile institutional type paint job. The flexible see through curtains are great for the fronts. Paint panels to match/coordinate the curtain colors. Need help with color combinations, a schools interior design/decorating class/instructor is a great resource. If you want to do it up big, have the design class paint a mural or so depicting welding/layout in action. Yes, there are facilities that use 1/8 -1/4" 4' X ? or 5' X ? ASBESTOS. They shall remain anonymous.
If you are interested in a picture of an educational welding shop; search the domain address below and click on the welding instructor http://www.ualocal740.ca
If you are interested in a shop lay out for welder training, then i will send you a picture of our facility inside.
We have our facility completed with concrete blocks.
The concrete blocks the sound from the next welding booth.
We used only 4" concrete blocks. But, it will be permanent.
