Capacitor start? / run?
Before you burn your house down take it to motor repair shop, I am sure they can tell you at a glance.
Generally speaking if its a 110 VAC there will be only 1 load line (black), a neutral (common)(white) line and a frame ground (green) where as most 220's have 2 load lines Black & White and a ground.
That should be enough information to get you a divorce.
