“THE ‘MIGHTY MITE’ SOLDER ALLOY”
This exceptional silver reinforced alloy is suitable for all dissimilar metals,chrome plated steels,
stainless steel,copper,brass and bronze.
IDENTIFICATION: Silver Spool
APPLICATION: Torch,Soldering Iron,Induction Heating
CRONABRAZE 92C SUPERIOR ADVANTAGES:
• COMPLIES WITH ALL FOOD AND BEVERAGE RESTRICTIONS
• 5 TIMES AS STRONG AS SOLDER
• LEAVES A SMOOTH, SHINY, SILVER DEPOSIT
• LOWEST HEAT FACTOR NEEDED FOR APPLICATION
• HIGHEST RESISTANCE TO CORROSION
• CONTAINS NO ZINC, CADMIUM, LEAD OR ANTIMONY
• AVAILABLE IN ACID CORE, ROSIN CORE AND SOLID
TECHNICAL INFORMATION:
TENSILE STRENGTH: 22,000 PSI (152 MPa)
TEMPERATURE: 425°F (218°C)
OPERATING PROCEDURES:
Do not apply flame directly to alloy.Direct heat to the base metal or either side of the joint.Alloy will
flow smoothly as soon as melting process commences.Flux residue is easily removed with hot water.
APPLICATIONS:
• STAINLESS STEEL AND CHROME PLATED STEEL • HOSPITAL EQUIPMENT
• FOOD PROCESSING EQUIPMENT • INSTRUMENT REPAIR
• IN PLACE HYDRAULIC RAM REPAIR
TECHNICAL TIPS:
Wherever common solder is subjected to vibration,sudden
jar or other stresses,use CRONABRAZE 92C and eliminate
joint failures.
If additional flux is required,EAGLE F920 and
F930 paste flux are recommended.
CONFIDENTIAL MATERIAL, REPRODUCTION, IN WHOLE OR IN PART, PROHIBITED Printed in U. S. A. (Rev. 7/ 01)
PART
NO.
CW1020
CW1021
CW1816
CW1815
CW1819
CW1818
CW1817
ELECTRODE
SIZE
1/16 x 9 ft. Acid Core
1/16 x 1 lb. Acid Core
1/8 x 1 lb. Acid Core
1/16 x 9 ft. Rosin Core
1/16 x 1 lb. Solid
1/8 x 1 lb. Solid
1/8 x 5 lbs. Solid
CRONATRON WELDING SYSTEMS, INC.
CRONABRAZE ™ 92C
WE 11.1 Corporate, Research & Distribution Hdqrs: 6510 Northpark Blvd. Charlotte, NC 28216-2367/ 800-843-0763/ www.cronatronwelding.com
Return to Index
