Up Topic Welding Industry / General Welding Discussion / Magnesium filler metal
- - By HAZ Date 01-14-2005 16:46
Dear Sirs,
I am looking for ASTM ZE41A rods.
It is a Mg alloy containing :
%Zn [3,5-5.0]
%RE [0.75-1.75]
%Zr [0.4-1.0]
%Mn [<0.15]
%CU [<0.10]
%Fe [0.01]
%Ni [0.01]
%Others [<0.30]
%Mg bal
Please help me to find a producer or a dealer.
Thank you
Paolo
Parent - - By Lawrence (*****) Date 01-14-2005 18:27
Here is a filler metal chart
http://www.lawires.com/t-mag2.htm#3.1.2
The chart suggests you use EZ33 which is AMS 4396
http://www.aircraftmaterialsuk.com/data/magnesium/ez33a.html
Neither link provided information on distortion control, Preheat or post weld stress relief. These items may merit consideration however.
Parent - By HAZ Date 01-18-2005 09:12
Thank you.
Much apprecciated
Paolo
Parent - By harleyhitman (**) Date 01-19-2005 12:20
CRONAMIG ™ 333M
Whenever there is the slightest doubt as to the right alloy to use, CRONAMIG 333M is
the “worry-free” solution. Exceptional results on every type of steel.
SURE-SLIDE ™ , Cronatron’s exclusive, patented final finish coating process, protects
the wire from oxidation, enhances stable arc transfer along with maximum wire feed-ability
and prevents flaking that may obstruct feed rolls and contact tips.
SUPERIOR ADVANTAGES:
• Excellent high-strength, crack-free welds on
all steels and combinations of steels
• Provides tough welds with no fumes or spatter
• Work-hardens in use
• Low amperage
• All-position
APPLICATIONS:
• Crane booms
• Tool steels
• Leaf springs
• Gear teeth
TECHNICAL INFORMATION:
Tensile Strength: 125,000 PSI (862 MPa)
Elongation: Up to 35% for shock and crack resistance
Hardness: Rc 20 – 25
WIRE DIA.
INCHES (mm)
SPOOL/COIL
LBS. (kg)
PART
NO.
.035 (0.9) 10 (4.5) CW1787
.035 (0.9) 25 (11.3) CW1936
.045 (1.2) 10 (4.5) CW1786
.045 (1.2) 25 (11.3) CW1937
• Worm drives and sprockets
• Chain links and draw bars
• Difficult and dissimilar steels
• Broken bolt extraction
WE 228 Corporate, Research & Distribution Hdqrs: 6510 Northpark Blvd. Charlotte, NC 28216-2367/800-843-0763/www.cronatronwelding.com
CONFIDENTIAL MATERIAL, REPRODUCTION, IN WHOLE OR IN PART, PROHIBITED Printed in U. S. A. (2/ 04)
CRONATRON ®
Techni cal Information
FOR OPERATING PARAMETERS REFER TO WE 55
Return to Index
Parent - By harleyhitman (**) Date 01-19-2005 12:22
THE “ALL IN ONE” ALLOY
Wherever there is the slightest doubt as to the right electrode to use,CRONAWELD 333 is the “worry
free ” solution..Exceptional results on every type of steel.
IDENTIFICATION: Printed Electrode,TIG Flagged One End
APPLICATION: AC or DC Reverse Polarity
CRONAWELD 333 SUPERIOR ADVANTAGES:
• EXCELLENT HIGH STRENGTH, CRACK FREE WELDS ON ALL STEELS AND
ALL COMBINATIONS OF STEELS
• PRODUCES STABLE ARC WITH OPEN CIRCUIT VOLTAGE AS LOW AS 55 VOLTS
• PROVIDES TOUGH AND CORROSIVE RESISTANT WELDS WITH NO FUMES OR SPATTER
• WORK HARDENS IN USE
• HIGH HEAT RESISTANCE
TENSILE STRENGTH: 125,000 PSI (862 MPa)
ELONGATION: UP TO 35%, FOR SHOCK
AND CRACK RESISTANCE
HARDNESS: Rc 20-25
OPERATING PROCEDURES:
Use AC or DC Reverse polarity,main-
tain a medium to short arc.A stringer or
weave bead is recommended for flat
and horizontal welds.
APPLICATIONS:
• CRANE BOOMS
• TOOL STEELS
• LEAF SPRINGS
• GEAR TEETH
• WORM DRIVES & SPROCKETS
• CHAIN LINKS & DRAW BARS
• DIFFICULT & DISSIMILAR STEELS
• BROKEN BOLT EXTRACTION*
CONFIDENTIAL MATERIAL, REPRODUCTION, IN WHOLE OR IN PART, PROHIBITED Printed in U. S. A. (Rev. 7/ 01)
PART
NO.
CW1877
CW1049
CW1048
CW1047
CW1046
ELECTRODE
SIZE
1/16
3/32
1/8
5/32
3/16
AMPS
30-45
60-90
80-120
110-160
160-240
*For detailed instructions see Technical Sheet
WE 17.1 For ‘Stud Stretcher’ kit order No. CW3030.
CRONATRON WELDING SYSTEMS, INC.
CRONAWELD ™ 333
COMBO PAC ......CW1729 MULTIPLE SIZES
and EXTRA VALUE!
PART NO.
CW1993
CW1898
CW1899
CW1900
SIZES
CRONATIG 333T
.035 x 36
1/16 x 36
3/32 x 36
1/8 x 36
PART NO.
CW1936
CW1937
CW1787
CW1786
SIZES
CRONAMIG 333M
.035 x 25 lbs.
.045 x 25 lbs.
.035 x 10 lbs.
.045 x 10 lbs.
WE 17 Corporate, Research & Distribution Hdqrs: 6510 Northpark Blvd. Charlotte, NC 28216-2367/ 800-843-0763/ www.cronatronwelding.com
Return to Index
