Up Topic Welding Industry / General Welding Discussion / want to start weld shop
- - By pjquinn Date 01-22-2005 01:33
want to start a small welding shop what the best way to find work to do?
Parent - - By NEQA (**) Date 01-26-2005 13:13
Where are you located?
Parent - By pjquinn Date 01-26-2005 22:08
i am located in akron ohio
Parent - - By testweldguy (**) Date 02-02-2005 07:56
Advertise....
Parent - - By jer (**) Date 02-02-2005 18:07
Design a short sales letter & sales fax sheet. Send to all machinery builders, stamping companys, machine shops, general contractors and anybody else you can think of. Think of who you know now that works at a company where you may be able to get work, and ask that they go to bat for you.
Calling a company and trying to setup an appointment to meet. Also repetitiveness usually works to, calling, sending a letter, sending a fax, e-mail whatever just do it again and again.
Think production welding, custom fabrication, repair welding, railings and platforms etc... Do your homework, you may need to be certified, you may need to know any and all codes involved.
Put a business plan together on equipment needed. possible fields of work etc.
Good luck
Parent - By pjquinn Date 02-02-2005 22:21
thanks for the info
